MrQuetzal Posted February 28, 2016 Posted February 28, 2016 I have thought to change the rear tire of my vfr honda, but the previous owner apparently had a smaller tire, please, I might advise that number of tire brand will look better and I use it for long trips Quote
coupedupsubie Posted February 28, 2016 Posted February 28, 2016 If it is for your 750 then it is a 170/60/17. I have only put 1500 miles on them but am very happy with the Metzler Roadtec Z8 Quote
Member Contributer CornerCarver Posted February 28, 2016 Member Contributer Posted February 28, 2016 I have thought to change the rear tire of my vfr honda, but the previous owner apparently had a smaller tire, please, I might advise that number of tire brand will look better and I use it for long trips If it is for your 750 then it is a 170/60/17. I have only put 1500 miles on them but am very happy with the Metzler Roadtec Z8 Provide us with the year of the VFR that you have. As the second poster stated some 750s have a 170 rear tire. Tell us also a little about the roads where you ride and the "long trips" ad rate the following from most important to least important in how you ride and value tires: Long tire life Cold weather grip Wet weather performance Ultimate performance grip Cost If you reorder these to suit your most important criteria for judging then we can point you in a direction for a good quality tire that compromises to suit your needs best. By the way, welcome aboard! Quote
