flattrack Posted December 31, 2015 Share Posted December 31, 2015 question about the F4 shock which is a popular replacement for the VF500F junker.can the mount with the damping adjuster be unscrewed from the shaft while the shock is charged with gas/oil? Would be nice to see a part blowup of how this mechanism works since I have not had one apart. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted December 31, 2015 Member Contributer Share Posted December 31, 2015 ? Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted December 31, 2015 Member Contributer Share Posted December 31, 2015 I think yes . The pic is of a 2005 shock but i believe the F4 is made the same . Link to comment Share on other sites More sharing options...
Member Contributer RC36Rider Posted January 1, 2016 Member Contributer Share Posted January 1, 2016 Better release the gas charge first, though. Not sure how nasty / dangerous it is but that needle running up the shaft is definitely under pressure. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted January 1, 2016 Member Contributer Share Posted January 1, 2016 Needle enters in from the other side of the shaft and can not be removed from the end pictured . Link to comment Share on other sites More sharing options...
Member Contributer RC36Rider Posted January 1, 2016 Member Contributer Share Posted January 1, 2016 Needle enters in from the other side of the shaft and can not be removed from the end pictured .Ooops! My bad. Sorry. Link to comment Share on other sites More sharing options...
flattrack Posted January 5, 2016 Author Share Posted January 5, 2016 well now I know what's inside. I suspect the shock I had didn't have much gas charge left as I could exercise the shock by hand after I removed the spring. I carefully drilled a very small hole in the cap where the bump is. with the gas released everything in the reservoir came apart easily. The cap was blank so I will add my own schrader. I pulled off the lower mount eyelet and will do the machining for the extension legs.I realized the bladder on this shock is reversed in orientation in the reservoir compared to the rebuilds I have seen on videos. Which means the gas is outside the bladder and the bladder expands rather than compress when the shock is compressed. Now would be the time for some expert advice :) Should I make my own endcap which holds the bladder in the usual position and then just o-ring the other end? Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted January 7, 2016 Member Contributer Share Posted January 7, 2016 well now I know what's inside. I suspect the shock I had didn't have much gas charge left as I could exercise the shock by hand after I removed the spring. I carefully drilled a very small hole in the cap where the bump is. with the gas released everything in the reservoir came apart easily. The cap was blank so I will add my own schrader. I pulled off the lower mount eyelet and will do the machining for the extension legs. I realized the bladder on this shock is reversed in orientation in the reservoir compared to the rebuilds I have seen on videos. Which means the gas is outside the bladder and the bladder expands rather than compress when the shock is compressed. Now would be the time for some expert advice :) Should I make my own endcap which holds the bladder in the usual position and then just o-ring the other end? Send Jamie a email. http://www.vfrdiscussion.com/forum/index.php/user/6344-jamiedaugherty/ Link to comment Share on other sites More sharing options...
