Member Contributer BuZZ Posted September 9, 2015 Member Contributer Share Posted September 9, 2015 I was cleaning my bike this afternoon, and I noticed that the front axle is not "symmetrical". There is a big bolt at the end on the right hand side, bot nothing on the left. Should I be worried? Thanks for your help! Link to comment Share on other sites More sharing options...
Member Contributer mk2davis Posted September 9, 2015 Member Contributer Share Posted September 9, 2015 You are fine. The side that is round has a shoulder, and the axle only tightens from one side. Link to comment Share on other sites More sharing options...
Member Contributer BuZZ Posted September 9, 2015 Author Member Contributer Share Posted September 9, 2015 Ouf ! Thank you very much! I'm going for a ride during the weekend, not a good time to miss a part! Link to comment Share on other sites More sharing options...
Member Contributer The mailman Posted September 9, 2015 Member Contributer Share Posted September 9, 2015 When you remove that big nut from the right, you can stick a screwdriver or similar through those little holes on the left side and pull the axle out easier. - and don't let your calipers hang by the hoses when you pull those off. Always reattach them to the fork with at least one of their bolts. Changing your brakes and tires on a VFR is one of the easiest maintenance jobs you can do. Link to comment Share on other sites More sharing options...
Otaylor38 Posted September 9, 2015 Share Posted September 9, 2015 Yeah thats spot on how it should be that mate (: Link to comment Share on other sites More sharing options...
