Member Contributer VFR-SPORT Posted September 7, 2015 Member Contributer Share Posted September 7, 2015 Hi: I just bought a used Givi E460 Monokey rear trunk. It came with the Givi brake light setup. Looking at the wiring diagram, it looks like the Gr/Y (green/yellow) wire is the one that should be tapped to provide the brake light function. The Bl/Br seems to be just for the tail lights. It doesn't seem to work. Can anybody with a similar setup tell me what connection to use and also where would be the best place to tap into it? Thanks. Stan Link to comment Share on other sites More sharing options...
wera803 Posted September 8, 2015 Share Posted September 8, 2015 I have the E460 on my 5th gen. I think you are right, the Gr/Y is the hot and the Green is the ground. I tapped into both wires right at the taillight instead of relying on using a frame ground. I can tell you the small wires in the trunk break easy. The 2-pin connector between the mounting plate and trunk also gets some sort of film on it after a while and I have to take fine sand paper to it to clean it up a couple of times a year. If you bought the trunk used or it has been sitting around a while, check to be sure you are getting power back there starting at your tap and check at each connection. Link to comment Share on other sites More sharing options...
Member Contributer VFR-SPORT Posted September 8, 2015 Author Member Contributer Share Posted September 8, 2015 Thanks. I doubled checked that the lights in the trunk are working by connecting directly to battery through all the connection points. I will try again to tap into it and a ground somewhere. On the 1200 there is really no exposed wires around the tail light section that I can see. Link to comment Share on other sites More sharing options...
