RobertDe Posted July 4, 2015 Share Posted July 4, 2015 Hi. Could you help mi to interpretate this? Is it one blink or more? I'm really confused. The engine runs unevenly at constant revolutions 3000-4000 RPM . Gently accelerates or slows down. Where to find the cause? Is it one blink and means MAP sensor problem? Robert Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted July 4, 2015 Member Contributer Share Posted July 4, 2015 Steady 4 second "FI" blink . FI light blinks - 0Light remains onEngine will not startCauses:1. Open or short circuit at the input power line of the ECU2. Faulty engine stop relay3. Faulty engine stop switch4. Faulty bank angle sensor5. Faulty ECM6. Blown main fuse B (30A)7. Blown engine stop fuse (10)8. Blown fuel pump fuse (30A)9. Open circuit in engine stop switch ground wire.`````````````````````````````````````````````FI light blinks - 0Engine operates normally1. Blown malfunction indicator bulb2. Open or short circuit in malfunction indicator wire3. Faulty ECM`````````````````````````````````````````````FI light blinks - 0Engine operates normally1. Short circuit in malfunction indicator wire2. Short in service check connector wire3. Faulty ECM`````````````````````````````````````````````FI light blinks - 1engine operates normally1.Loose or poor contacts on MAP sensor connector2. Open or short circuit in MAP sensor wire3. Faulty MAP sensor`````````````````````````````````````````````FI light blinks - 2engine operates normally1. Loose or poor connection of the MAP sensor vacuum tube2. Faulty MAP sensor`````````````````````````````````````````````FI lamp blinks - 7Hard start at low temp.1. Loose or poor contact on ECT sensor2. Open or short in ECT sensor wire3. Faulty ECT sensor`````````````````````````````````````````````FI light blinks - 8Poor engine response when opening throttle quickly1. Loose or poor connection on TP sensor2. Open or short circuit in TP sensor wire3. Faulty TP sensor`````````````````````````````````````````````FI light blinks - 9engine operates normally1. Loose or poor contact on IAT sensor2. Open or short circuit in IAT sensor wire3. Faulty IAT sensor`````````````````````````````````````````````FI light blinks - 10engine operates normally at low altitudeengine operates roughly at high altitude1. Loose or poor contact on BARO sensor connector2. Open or short in BARO sensor wire3. Faulty BARO sensor`````````````````````````````````````````````FI light blinks - 11engine operates normally1. Loose or poor contact on vehicle speed sensor connector2. Open or short circuit in vehicle speed sensor wire3. Faulty vehicle speed sensor`````````````````````````````````````````````FI light blinks - 12engine does not start1. Loose or poor contact on # 1 injector connector2. Open or short in # 1 injector wire3. Faulty # 1 injector`````````````````````````````````````````````FI light blinks - 13# 2 injector problem, follow #1 above`````````````````````````````````````````````FI light blinks - 14# 3 injector problem, follow #1 above`````````````````````````````````````````````FI light blinks - 15# 4 injector problem, follow #1 above`````````````````````````````````````````````FI light blinks - 18engine does not start1. Loose or poor contact on cam pulse generator connector2. Open or short circuit in cam pulse generator3. Faulty cam pulse generator`````````````````````````````````````````````````` ``FI light blinks - 19engine does not start1. Loose or poor contact on ignition pulse generator connector2. Open or short circuit in ignition pulse generator3. Faulty ignition pulse generator`````````````````````````````````````````````````` ``FI light blinks - 20engine operates normallydoes not hold the self-diagnosis data Here a great topic on the subject . http://www.vfrdiscussion.com/forum/index.php/topic/16-fi-light-how-to-read-error-codes/ Roll On .. Link to comment Share on other sites More sharing options...
RobertDe Posted July 4, 2015 Author Share Posted July 4, 2015 Here a great topic on the subject . http://www.vfrdiscussion.com/forum/index.php/topic/16-fi-light-how-to-read-error-codes/ Roll On .. I know this tables :) Ok I'll try there :) Thank you :) Robert Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted July 4, 2015 Member Contributer Share Posted July 4, 2015 Your welcome . Roll On .. Link to comment Share on other sites More sharing options...
