LosLobos Posted April 18, 2015 Share Posted April 18, 2015 New sprockets/chain, now clutch cover won't go back on - seems clutch push rod sticks out too far ... And yeah I pressed clutch lever with cover off, which made the gap worse of course .... Are you supposed to just tighten everything down with the cover bolts ? ? ? Or what ? Advice needed. I ' m supposed meet friends for ride in two hours. Great. Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted April 18, 2015 Member Contributer Share Posted April 18, 2015 Not unusual for the clutch slave piston to extend out a bit when its off the bike. You should be able to line the parts up and push it gently back onto the pushrod, then snug up the bolts. Same sort of thing as pushing brake pistons back into the calliper when you change pads. Link to comment Share on other sites More sharing options...
LosLobos Posted April 18, 2015 Author Share Posted April 18, 2015 Not unusual for the clutch slave piston to extend out a bit when its off the bike. You should be able to line the parts up and push it gently back onto the pushrod, then snug up the bolts. Same sort of thing as pushing brake pistons back into the calliper when you change pads. Thanks ! I think I got it back on correctly. Link to comment Share on other sites More sharing options...
