Mmahmoud72 Posted February 7, 2015 Share Posted February 7, 2015 Hi guys, I have a vfr1200f 2010 and I am going to change the spark plugs, however I did not find a 9E-9HES one I only found IMR 9C-9H, does it will work efficient ? Link to comment Share on other sites More sharing options...
Tamworth Posted February 7, 2015 Share Posted February 7, 2015 Unless there is a problem with a spark plug I wouldn't bother replacing them. nothing can be gained from doing so Link to comment Share on other sites More sharing options...
Member Contributer Skids Posted February 7, 2015 Member Contributer Share Posted February 7, 2015 Why do you want to change them? What's the recommended replacement schedule and how many miles has your 1200 done? Link to comment Share on other sites More sharing options...
Mmahmoud72 Posted February 7, 2015 Author Share Posted February 7, 2015 My bike is 6500 mile And I have errors 77 & 79 what they are for? Link to comment Share on other sites More sharing options...
Tamworth Posted February 7, 2015 Share Posted February 7, 2015 My plugs are fine at 35,000 mi. Those error codes relate to the throttle by wire system Link to comment Share on other sites More sharing options...
Member Contributer Skids Posted February 8, 2015 Member Contributer Share Posted February 8, 2015 My plugs are fine at 35,000 mi. Those error codes relate to the throttle by wire system Mmahmoud72, have you downloaded the VFR1200 Service Manual from the downloads section? Page 6-15 give the details of the error codes: The numbers at the right-hand side are the page numbers to find how to deal with the error code. Hope that helps. Link to comment Share on other sites More sharing options...
Mmahmoud72 Posted February 8, 2015 Author Share Posted February 8, 2015 Thank you very much, I downloaded the manual. Link to comment Share on other sites More sharing options...
