antonypo Posted January 25, 2015 Share Posted January 25, 2015 Hi everyone. This is my 1st post so sorry if its been asked before. I just bought my lovely red 1200f 11 reg which lucky for me the original owner had heated grips put on it. I see from the internet they have 3 settings. Does anyone know how to use these settings? I press it and it flashes red so it does come on but how do i access the other settings? Thanks Link to comment Share on other sites More sharing options...
Member Contributer Marsman99 Posted January 26, 2015 Member Contributer Share Posted January 26, 2015 There are three temp settings starting at high, then medium, then low, then off. Pushing the button for 1-2 seconds activates the switch. Once activated, it will flash several times then settle into the setting. So, once you initially push and it flashes it will be in high which is indicated when the light remains on. If you push again for 1-2 seconds it will again flash and change to the next setting and the light will remain on. And so on. If you want the low setting you'll need to go through the entire sequence. Link to comment Share on other sites More sharing options...
antonypo Posted January 26, 2015 Author Share Posted January 26, 2015 Great - thanks a lot. Seems obvious i suppose but the light was always on when i pressed it so i needed to ask. Cheers Antony Link to comment Share on other sites More sharing options...
