GadiantonRob Posted March 25, 2014 Share Posted March 25, 2014 If you look at the parts fiche on partzilla, it shows an exploded view of the pulse gen area, and that piece goes just like phantom said, flat side toward s/c. Also, here's this link if you need more info: http://vfrworld.com/forums/showthread.php/22135-Starter-Clutch-Repair-VFR750-With-Pictures Link to comment Share on other sites More sharing options...
Guest Posted March 25, 2014 Share Posted March 25, 2014 I looked at the fiche actually before posting (pulse generator) but couldn't see it and still can't on that diagram. Then I thought maybe on the transmission view but still nothing. I'm either blind or I don't know. Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
The Phantom Posted March 25, 2014 Share Posted March 25, 2014 It's part 13 in one fiche I found, and part 22 in another... Link to comment Share on other sites More sharing options...
Guest Posted March 25, 2014 Share Posted March 25, 2014 Sorry guys, i dont mean to be a pin in the ass but this is the pulse gen exploded view.... I dont see it anywhere :S Link to comment Share on other sites More sharing options...
The Phantom Posted March 25, 2014 Share Posted March 25, 2014 Of course now I can't find those fiche diagrams... This is an RC30, very similar (as are the earlier VF/VFRs) - your flange washer is on the primary drive shaft at bottom right of the image. Here's an actual VFR - same thing, visible on the primary drive shaft to the right of the clutch: And DON'T FORGET to put that little pin - 17 in diagram - back in before you button it all up. Link to comment Share on other sites More sharing options...
Guest Posted March 25, 2014 Share Posted March 25, 2014 ok great thanks. yeah i ordered a new one. 50c piece, didnt want to start fidling with taking out the old one. is it normal that its a bit loose? seems like the ID of the piece is a bit larger than the OD of the spline Link to comment Share on other sites More sharing options...
The Phantom Posted March 25, 2014 Share Posted March 25, 2014 Yeah its only purpose is to stand the starter clutch off the starter gear. It's not loose once you tighten up the bolt that fastens the starter clutch to the primary drive shaft. Link to comment Share on other sites More sharing options...
Guest Posted March 25, 2014 Share Posted March 25, 2014 Sounds good. Thanks to everyone who chimed in Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
Guest Posted March 27, 2014 Share Posted March 27, 2014 well people, i am thrilled to report tat the starter worked perfectly 10 for 10 last night and the bike is now fully reassembled and ready to take out.... if only mother nature would let me. once again thank you to everyone who chimed in. as a first topic, i value the community's help Link to comment Share on other sites More sharing options...
JIMLARCH Posted April 17, 2014 Share Posted April 17, 2014 Sounds good. Thanks to everyone who chimed in Sent from my SGH-I337M using Tapatalk Did you replace the starter clutch? I hope your problem is cured, but I am wondering if it is. I had, and likely still have the same problem. Took the bike out of storage. Had drained the carbs, so switched the gas on and used the starter about 8 times to pump fuel through to carbs. Not a problem. Bike started and I let it run for a few minutes. I switched it off and the exact thing happened as in the beginning of your video (the first 15 seconds). The clattering. I put the bike into gear and pushed it forward with the engine off. Then I tried the starter again. It missed and then started. Tried 2 or 3 times after that and it started perfectly. Today I decided to go for a ride. Used the starter and it wheezed quietly, but didn't start. Tried a couple of times, same result. Started 3rd time. Left it running, went for a 20 mile ride. Came back, tried starter twice, started instantly, no problems. I also have the vfrness. I noticed that the wires are very tight across the battery, and the fuse is squashed when the seat is put on. I will try starting the bike with the seat off, and the wires not squashed when I next try starting the bike. Will update when I have done so. Link to comment Share on other sites More sharing options...
Guest Posted April 17, 2014 Share Posted April 17, 2014 I did end up changing the starter clutch. The problem has not reappeared since. Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
JIMLARCH Posted April 17, 2014 Share Posted April 17, 2014 I did end up changing the starter clutch. The problem has not reappeared since. Sent from my SGH-I337M using Tapatalk Thanks. I checked mine last year because of the occasional clank, miss, start ups. No apparent cracks or problems. Guess I may have to do the same as you. We'll see. Link to comment Share on other sites More sharing options...
Guest Posted April 17, 2014 Share Posted April 17, 2014 There were also no cracks or obvious signs of wear on mine other than on the back plate of the starter clutch where you could see where the rollers had moved to and from. I imagine the tolerances are quite small for it to work properly sadly Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
