Guest MBH300 Posted August 19, 2013 Share Posted August 19, 2013 Anyone know if or ever tried swapping a 98-01 gauge cluster to a 94-97 My 95 has 98-99 fairings with no gauge bezel. Just trying to decide if I should modify the 98-01 bezel or try swapping in the whole cluster Link to comment Share on other sites More sharing options...
Member Contributer JETS Posted August 23, 2013 Member Contributer Share Posted August 23, 2013 I reassembled a 97 cluster and bezel out of two partially damaged sets, and from visualizing that, I wouldn't see how you could drop a 98 style panel into a 97 electrically. Senders and ECU take-offs would likely not be compatible. Look at the two wiring diagrams and the blow-ups of the panel backs, connectors to see differences. Maybe you can sort out a sprare harness off a 98 to adapt to the 97 feeds to the panel. Now maybe you could physically form a skirt from ABS that adapts the 97 cluster outer cover into the 98 fairings. Use a cut up 98 spare outer cluster cover and bond with two part urethane and filler to match to the face of a 97 panel, then paint to match. Good luck. Link to comment Share on other sites More sharing options...
Member Contributer apexandy Posted August 24, 2013 Member Contributer Share Posted August 24, 2013 I think it might be possible... If people can fit CBR1000RR and 600RR gauges to a 4th gen (it has been done on this forum) I would think a 5th gen gauge could work. However a speedohealer might be necessary. Link to comment Share on other sites More sharing options...
erbilabuc Posted October 8, 2013 Share Posted October 8, 2013 i have my cluster Ill let you have from a 95 Link to comment Share on other sites More sharing options...
