Guest corpsy Posted August 2, 2013 Share Posted August 2, 2013 just baught a 3rd gen1990 that has been sitting for a long while took it for my first ride and it worked awesome buuut i took a peek under it after and saw a few drips of coolant off with the fairings.... looks good and dry on the pipes inbetween the heads,seem to be on the left side where the lower rad hose is (not the hose) is that a waterpump? that seems to be the only wet area.are those covers common to leak? Link to comment Share on other sites More sharing options...
Member Contributer rangemaster Posted August 2, 2013 Member Contributer Share Posted August 2, 2013 Because it was sitting the shaft seal probably dried out and it's leaking from there. Give it a while for the coolant to swell up the seal and hope it stops leaking. Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2013 Share Posted August 2, 2013 ya that sounds like best scenario i could hope for i squezed the life out of the hoses while there were hot and under pressure nothing came out anywhere thanks! Link to comment Share on other sites More sharing options...
