Member Contributer karhawk Posted September 2, 2012 Member Contributer Share Posted September 2, 2012 I got a 112 DID Xring vm chain with stock front sprocket and 45t rear but it seems I'm one link short. I adjust concentric counter clockwise to shorten distance between gears right? Do I have to flip concentric and how is that accomplished? Many thanks Chris Oakland, Ca. Link to comment Share on other sites More sharing options...
SEBSPEED Posted September 2, 2012 Share Posted September 2, 2012 No need to flip, you can if you want more ride height. Rotate forward, the axle is at 12:00 from the factory. Link to comment Share on other sites More sharing options...
Member Contributer karhawk Posted September 2, 2012 Author Member Contributer Share Posted September 2, 2012 It doesn't adjust enough to make the 45t rear fit, I read somewhere around here that the stock 112 link chain will work. Link to comment Share on other sites More sharing options...
SEBSPEED Posted September 2, 2012 Share Posted September 2, 2012 Maybe with a 15T front sprocket? If you've got the eccentric all the way forward & it doesn't fit, you are SOL. Link to comment Share on other sites More sharing options...
Member Contributer karhawk Posted September 3, 2012 Author Member Contributer Share Posted September 3, 2012 Maybe with a 15T front sprocket? If you've got the eccentric all the way forward & it doesn't fit, you are SOL. Yeah I'm pretty SOLI need one inner link for a DID 50VM X ring chain anybody?? Link to comment Share on other sites More sharing options...
bayarearider Posted September 3, 2012 Share Posted September 3, 2012 Hey Chris, I've got a wrench in my hood that has an autoshop but also runs an AMA supersport team. I can ask him for the bits you need when he reopens. What size again? ps-Did you get your wheel bearing sorted? Link to comment Share on other sites More sharing options...
Member Contributer karhawk Posted September 3, 2012 Author Member Contributer Share Posted September 3, 2012 Hey Chris, I've got a wrench in my hood that has an autoshop but also runs an AMA supersport team. I can ask him for the bits you need when he reopens. What size again? ps-Did you get your wheel bearing sorted? Thanks I got it sorted out, my bike is running great except for this chain issue. I have a DID50VM X-ring or DID 530 VM Gold, it has O rings. I need one inner link and one connecting link. Link to comment Share on other sites More sharing options...
bayarearider Posted September 8, 2012 Share Posted September 8, 2012 Was finally able to talk to the shop today. He didn't have any 530 chain but said when you're able locate a match, make sure you have 2 master links. Hopefully you'll have time to get her together for a Sierra run coming up.. Link to comment Share on other sites More sharing options...
Member Contributer trjerm Posted September 8, 2012 Member Contributer Share Posted September 8, 2012 When you do the sierra rt. give me a call. Just drove over to markleville today for flyfishing trip, new pavement on 88 to @ least Woodfords. Just a lot of rocks on morman immagrant after last weekends storms. caught 5 fish 18+ and a lot between 8 & 12 and the last one 14+ tom Link to comment Share on other sites More sharing options...
Member Contributer karhawk Posted September 17, 2012 Author Member Contributer Share Posted September 17, 2012 Was finally able to talk to the shop today. He didn't have any 530 chain but said when you're able locate a match, make sure you have 2 master links. Hopefully you'll have time to get her together for a Sierra run coming up.. Thanks, I sent the 112 back and got a 114t which fits perfectly, I like the extra grunt I've got now! Link to comment Share on other sites More sharing options...
bayarearider Posted September 17, 2012 Share Posted September 17, 2012 Was finally able to talk to the shop today. He didn't have any 530 chain but said when you're able locate a match, make sure you have 2 master links. Hopefully you'll have time to get her together for a Sierra run coming up.. Thanks, I sent the 112 back and got a 114t which fits perfectly, I like the extra grunt I've got now! Think you may want to make this run? I'm looking to be riding past Oakland on route to Fairfiled for a roundup.. Sign Up. http://www.vfrdiscus...rday-sept-22nd/ Link to comment Share on other sites More sharing options...
Member Contributer karhawk Posted September 19, 2012 Author Member Contributer Share Posted September 19, 2012 Was finally able to talk to the shop today. He didn't have any 530 chain but said when you're able locate a match, make sure you have 2 master links. Hopefully you'll have time to get her together for a Sierra run coming up.. Thanks, I sent the 112 back and got a 114t which fits perfectly, I like the extra grunt I've got now! Think you may want to make this run? I'm looking to be riding past Oakland on route to Fairfiled for a roundup.. Sign Up. http://www.vfrdiscus...rday-sept-22nd/ Thanks I have plans, have a great ride! It looks like a good route. Link to comment Share on other sites More sharing options...
