Member Contributer bryan217 Posted August 8, 2012 Member Contributer Share Posted August 8, 2012 This is not the typical, 'how do I remove the stupid Honda clips on the fairing'. I actually had no problem at all removing them, didn't break or lose any. But now that I'm putting it back together, I can't figure out how to put the clips back in and have them lock. BTW, what a pain to change the headlight bulbs on the 6th gen. I had one of the low beams go out, and knowing it was so much work, I decided to replace the other low beam while I was there. The fairings weren't that bad. Too be honest, the hardest thing was removing the plug from the back of the bulbs. But I got it done, got everything back in place, but can't seem to get the clips to catch. Somebody please tell me what I'm missing. Link to comment Share on other sites More sharing options...
Monk Posted August 8, 2012 Share Posted August 8, 2012 You have to pull the centre part back to where it is not flush on top (needs to be about 16th of an inch above the cap) so the part that goes in the hole is able to come back to allow the side to close. And that won't happen unless you have 3 hands(not really), but you'll need to spread the pointed tip to get the middle to retract. Piece of cake. Link to comment Share on other sites More sharing options...
jugornot Posted August 8, 2012 Share Posted August 8, 2012 Push in to pull out. Pull out to push in. Well you actually push out from the back to push in, but that ain't near as cool. Link to comment Share on other sites More sharing options...
Member Contributer KevininAtlanta Posted August 23, 2012 Member Contributer Share Posted August 23, 2012 Above responses are agreed with....needle nose pliers help achieve what they are stating. I feel your pain as last weekend I disconnected my headlights. I applied some dielectric grease to the prongs on the bulbs to make them easier to disconnect the next time I have to do so. I and others us GM clips as the Honda are difficult to use. GM TR240 clips (OEM 21077123) 25 for $6.00) Another alternative recommend to me: www.fastenerwharehouse.com/catalog/item56836/2509102.htm Kevin in Atlanta Link to comment Share on other sites More sharing options...
Jon28 Posted September 9, 2012 Share Posted September 9, 2012 Yes sir, those Honda clips are counter-intuitive Kevin, how do those GM clips work out? Any modification or direct replacement for our OEM? The price is much better!!!! Link to comment Share on other sites More sharing options...
bayarearider Posted September 9, 2012 Share Posted September 9, 2012 http://www.motorcycle-superstore.com/4/22/434/38233/ITEM/Bolt-Motorcycle-Hardware-M6-Push-Rivets.aspx?WT.ac=SLIsearch These are the easy replacements Link to comment Share on other sites More sharing options...
Guest Posted September 10, 2012 Share Posted September 10, 2012 The 7th Gen clips are much nicer. Push the centre in to take out. Once out pull them out and you can simply push them in again. Link to comment Share on other sites More sharing options...
