Guest smithe2 Posted July 3, 2012 Share Posted July 3, 2012 Does anyone know all of the hardware used for the centerstand on a 96 vfr? I have a stand and the rod that connects underneath the bike, but I need the hardware. From what I can see on those for sale on Ebay there is a bracket and two springs, one to hold the stand up, and one inside the connecting rod to assist in lifting the bike. I just want to make sure that is all I'd need upon asking my local shop for, otherwise I may have to buy a complete stand online. Thanks Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted July 4, 2012 Member Contributer Share Posted July 4, 2012 Looks like all of the parts for a 4th-gen center stand, new from Ron Ayers, would set you back only about $150. All of the other parts (if you have the two biggest ones) would only cost you about $25. (The 3rd-gen is totally different and has a big cast iron bracket that bolts to the engine.) Ciao, Link to comment Share on other sites More sharing options...
cbkenison Posted July 4, 2012 Share Posted July 4, 2012 M8x20 bolt (I'm pretty sure), centerstand, pivot shaft, weird C-shaped bracket that springs attach to, 1 large spring with rubber housing, 1 smaller spring, and a washer. I attached both springs to the same points, as per the service manual. Link to comment Share on other sites More sharing options...
Guest Posted July 9, 2012 Share Posted July 9, 2012 M8x20 bolt (I'm pretty sure), centerstand, pivot shaft, weird C-shaped bracket that springs attach to, 1 large spring with rubber housing, 1 smaller spring, and a washer. I attached both springs to the same points, as per the service manual. Thanks for the bolt size, I'll be needing to buy that. I found a complete stand on ebay for 20 bucks so that should save me some trouble, plus I hate the honda shop by my house, the guys are very rude. Unfortunately my service manual nor owners manual have anything about assembly, which I found odd. I will have to do some digging on where the springs attach Link to comment Share on other sites More sharing options...
cbkenison Posted July 9, 2012 Share Posted July 9, 2012 Here's the page. Link to comment Share on other sites More sharing options...
Guest Posted July 10, 2012 Share Posted July 10, 2012 Thanks for the pic. I am having some trouble here, however. I have the larger spring attached and everything is assembled except the smaller spring. It appears both of the spring go on the same points, however I cannot find enough space on the centerstand where the larger spring already is. The only thing I can think of is to put the smaller spring inside the larger. Link to comment Share on other sites More sharing options...
Guest Posted July 10, 2012 Share Posted July 10, 2012 Nevermind, got it all on and the stand is functioning just fine. Still takes a decent amount of muscle to get it up but oh well. Thanks for all your help Link to comment Share on other sites More sharing options...
