Member Contributer karhawk Posted June 1, 2012 Member Contributer Share Posted June 1, 2012 I'm waiting on a 929 setup in the mean time what can be done about the stock shock tendency to bounce over freeway bumps, compression seems OK but rebound tends to launch you a little over bouncy areas. 07 R1 front seems pretty well planted so far. Thanks the italian stallion goes out again today! Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted June 1, 2012 Member Contributer Share Posted June 1, 2012 Since you have already improved the front, every budget induced flawed nuance of the stock rear will show in an uncompromisingly bright light. They are a few things that can help a little but none really worth doing if you have a 929 on the way. Link to comment Share on other sites More sharing options...
NakedViffer Posted June 1, 2012 Share Posted June 1, 2012 Do you have the rebound adjustment set to hard? Link to comment Share on other sites More sharing options...
