Member Contributer Africord Posted March 19, 2012 Member Contributer Share Posted March 19, 2012 I bought the above bag last fall because it seem to represent a good value and I wanted a bigger bag for touring. After last weekend, I'm not so sure. I took a short 150 mile trip and discovered when I removed the bag that a bunch of black material had been deposited all over the top of my red tank. I was able to clean it off with wax and grease removal spray, but I'd like to prevent it from happening at all. I suspect that this is excess dye/water proofing material, but I really don't know what it is. Anyone got a suggestion on how to address this? Link to comment Share on other sites More sharing options...
Monk Posted March 19, 2012 Share Posted March 19, 2012 Is the bottom surface of the bag a soft foam type ? If so it's just a suck bottom that is not only confined to cheap ! I had one once.....Sucked....... Nothing you can do to the bag's bottom...but you can buy some rubber shelf mats and cut a piece to go inbetween the bag and tank.... It also works well to sit on(passengers/etc.) to not slide on the seat...... What bag did you buy ? Link to comment Share on other sites More sharing options...
Member Contributer Africord Posted March 19, 2012 Author Member Contributer Share Posted March 19, 2012 Monk, see topic. I'll look into the rubber shelf mats. Link to comment Share on other sites More sharing options...
Monk Posted March 19, 2012 Share Posted March 19, 2012 Monk, see topic. I'll look into the rubber shelf mats. Oops.....If it was a snake, it would have bit me. Link to comment Share on other sites More sharing options...
