Lee 2002 Posted May 7, 2009 Author Share Posted May 7, 2009 92499A640 18-8 Stainless Steel Male-Female Thrd Adapter M8 X 1.25 Male End, M8 X 1.0 Female End In stock at $11.38 Each The OEM bolt is 8 X 1.25. So you will need the Male thread to have that pitch. Check the diameter of the HEX, it will need to be less than 22mm. Link to comment Share on other sites More sharing options...
Lee 2002 Posted May 7, 2009 Author Share Posted May 7, 2009 Many people have already done bushings. Your HD suggestion is a great option for those who don't have access to a lathe. I am happy that bushings fit your needs. But, it was my intention from the get-go to avoid any loose hardware. I did not want to swap bolts (short for long) and I did not want to have to keep track of bushings while Ken's Rack was not mounted. Thus, my hard point solution. Link to comment Share on other sites More sharing options...
Member Contributer Cdn Arctic Posted May 7, 2009 Member Contributer Share Posted May 7, 2009 Many people have already done bushings. Your HD suggestion is a great option for those who don't have access to a lathe. I am happy that bushings fit your needs. But, it was my intention from the get-go to avoid any loose hardware. I did not want to swap bolts (short for long) and I did not want to have to keep track of bushings while Ken's Rack was not mounted. Thus, my hard point solution. No bolts to swap, just take off the mount and top box, leave the spacers where they are and install the bolts to hold the spacers and the grab handle. Sure you have to use longer bolts, but you never go back to the shorter ones and as long as they are holding down both the spacers and the grab handle, nothing goes missing, except maybe the mounting rack and the top box. Link to comment Share on other sites More sharing options...
Lee 2002 Posted May 7, 2009 Author Share Posted May 7, 2009 But, it was my intention from the get-go to avoid any loose hardware. At the time the change-over is made you still have to keep track of the bushings. I am happy bushings work for you. They were not an acceptable solution for me. Link to comment Share on other sites More sharing options...
Member Contributer pronomad Posted May 7, 2009 Member Contributer Share Posted May 7, 2009 92499A640 18-8 Stainless Steel Male-Female Thrd Adapter M8 X 1.25 Male End, M8 X 1.0 Female End In stock at $11.38 Each The OEM bolt is 8 X 1.25. So you will need the Male thread to have that pitch. Check the diameter of the HEX, it will need to be less than 22mm. The hex would be a 14mm wrench size. My elementary geometry skills tells me the OD would be ~16.2mm so that should work. The entire spec of the spacer is below (sorry for the format). Strange that the female thread pitch would different, no? Eh, either way there's a enough engagement to hold the solo rack on reliably. Part Number: 92499A640 $11.38 Each Type: Male-Female Threaded Hex Male-Female Threaded Hex Type: Reducing Material Type: Stainless Steel Finish: Plain Stainless Steel Type: 18-8 Stainless Steel Body Length: 19.05 mm Body Length Tolerance: ±.005" Hex Width: 14 mm Hex Width Tolerance: ±.002" Male Screw Size: M8 Male Metric Thread Pitch: 1.25 mm Female Screw Size: M8 Female Metric Thread Pitch: 1 mm Threading: Partially Threaded Male Thread Length (B): 12.7 mm Female Thread Length (C ): 11.09 mm Rockwell Hardness: Minimum B83 Tensile Strength: 85,000 psi Thread Fit: Class 6g External; Class 6H Internal Specifications Met: American Society for Testing and Materials (ASTM) ASTM Specification: ASTM 581 Link to comment Share on other sites More sharing options...
Member Contributer pronomad Posted May 7, 2009 Member Contributer Share Posted May 7, 2009 Part Number: 92499A640 $11.38 Each Type: Male-Female Threaded Hex Male-Female Threaded Hex Type: Reducing Material Type: Stainless Steel Finish: Plain Stainless Steel Type: 18-8 Stainless Steel Body Length: 19.05 mm Body Length Tolerance: ±.005" Hex Width: 14 mm Hex Width Tolerance: ±.002" Male Screw Size: M8 Male Metric Thread Pitch: 1.25 mm Female Screw Size: M8 Female Metric Thread Pitch: 1 mm Threading: Partially Threaded Male Thread Length (B): 12.7 mm Female Thread Length (C ): 11.09 mm Rockwell Hardness: Minimum B83 Tensile Strength: 85,000 psi Thread Fit: Class 6g External; Class 6H Internal Specifications Met: American Society for Testing and Materials (ASTM) ASTM Specification: ASTM 581 Shit. I just realized 12.7 mm of thread is not going to be anywhere close to enough to pass through the grab handle and secure to the bike. MF. Link to comment Share on other sites More sharing options...
brownelvis Posted July 26, 2013 Share Posted July 26, 2013 I realize this is an older thread but I was wondering if anyone found a ready to buy solution similar to OP's to make the solo rack a quick release solution. I got hard bags on my VFR now and lining up the screw holes with the hard bag mounts/grab rails/solo rack to get the solo rack installed is a real pain now, if I had a set up like OP it would make my life wayyy easier as I only use the solo rack for touring. Link to comment Share on other sites More sharing options...
Lee 2002 Posted July 27, 2013 Author Share Posted July 27, 2013 I waited all day to reply - hoping that someone had found an off the shelf option. I can report that four years later I am still using the same bushings to mount Ken's Solo Rack. I can quickly remove four bolts and washers, throw them in the trunk and bring a passenger along for a ride with the handles already installed and solid. In a couple of seconds I can re-install Ken's rack and be back to my commuter set-up. If you can find the right diameter stock (or just close), you can easily fabricate these using nothing more than a hacksaw, file, drill press and tap. After 4 years this is still the ideal set up for my needs. Link to comment Share on other sites More sharing options...
Member Contributer Olive Posted July 28, 2013 Member Contributer Share Posted July 28, 2013 If you can find the right diameter stock (or just close), you can easily fabricate these using nothing more than a hacksaw, file, drill press and tap. Lee - can you post a detailed tutorial on how to fabricate these (using the easy mod-at home with few tools)? Or do you have any interest in fabricating and selling? I think you have found an ingenious solution! Link to comment Share on other sites More sharing options...
brownelvis Posted July 28, 2013 Share Posted July 28, 2013 A light bulb kind of went off as I looked at OP's post again and was browsing through McMaster-Carr's site to look at all kinds of fasteners. I could rig up something similar by using red loctite to join a length of m8 threaded rod to a m8 hex coupling nut, then use m8 screws to attach the solo rack to the remaining exposed thread on the coupling nuts I'm going to order some fasteners and play around with them and I'll report back. Any thoughts? Link to comment Share on other sites More sharing options...
Gerry Posted October 30, 2015 Share Posted October 30, 2015 I recently bought a 5th Gen rack from Ken (yes they are still available) for my 2001 VFR. Have to say the bike handles like a beaut with this. I did the Blue Ridge Parkway trip from Toronto. Keeping the luggage weight forward over the back wheel is sooooooo good for handling. The beauty of this rack for me is that it takes 2 minutes to install when I want to do my trips, and off it comes (just 4 bolts) for regular city biking. Link to comment Share on other sites More sharing options...
