Member Contributer stuartcj Posted January 19, 2009 Member Contributer Share Posted January 19, 2009 I have had for about 7 years a Micron Hi-level end section for my '94. I really liked it, but every time I rode the bike I got paranoid about the (fabulous) noise (the can is stamped with "NOT FOR ROAD USE" on the back and the police are a little fussy about such things around here). Many years back I contacted Micron and asked them if they did a "road legal" end-can that would fit on to this pipework and basically the answer was "no" so the whole thing languished under a bench in my garage. I'd really like to make use of this again with a new end-can, and being as Hi-level pipes for the '94 model are a. Very rare b. Very expensive I figured that as I have the most important part already (the actual "hi-level" part ) doing nothing in the garage finding a can somewhere would be the way to go. Would anyone have any idea if any other manufacturers can has an opening of 48mmm where the pipework enters ? I did think about finding someone who could make me a sleeve that steps up or down but I have no idea who would be able to do that (and of course I need the can dimensions anyway ). Mounting the pipe at the subframe end is easy enough as I still have the big circular whatsit that would go around a new can from the old one (it's adjustable) it's just the 48mm thing that's the problem. Thanks Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted January 19, 2009 Share Posted January 19, 2009 Hell yes, Micron makes a Euro compliant endcan. Let me go find it. Here you go, They call it the Delta+ and it's Euro legal. http://www.micronexhausts.com/product-details.html?autoid=60 The link is for a VFR800 can because the VFR750 isn't listed, but it's a simple thing to slide the 800's endcan onto your pipework. As long as they both have a 2" inlet, you're all set! Or you could fit a DB Dawg to your your existing can. Won't make it legal, but will make it quieter. http://www.ignitionproducts.com/Ignition/mufflers.html Link to comment Share on other sites More sharing options...
Member Contributer stuartcj Posted January 20, 2009 Author Member Contributer Share Posted January 20, 2009 Great....thanks for that , it looks like it would fit the bill ! The sizes seem good and the fitting looks the same so I may well give it a go. The db Dawg looks an interesting device too. The only problem I can see with that solution for me though is that (here in the UK anyway ) none-approved silencers have "NOT FOR ROAD USE " stamped on the end-plate. If we get pulled-over by the law it's one of the first things they look for (it may as well say "Fine me I'm Illegal" ) ;-) so I'd still have to constantly swap the whole pipe over. I'm going to check the pipe out that you suggested though. Thanks again. Hell yes, Micron makes a Euro compliant endcan. Let me go find it. Here you go, They call it the Delta+ and it's Euro legal. http://www.micronexhausts.com/product-details.html?autoid=60 The link is for a VFR800 can because the VFR750 isn't listed, but it's a simple thing to slide the 800's endcan onto your pipework. As long as they both have a 2" inlet, you're all set! Or you could fit a DB Dawg to your your existing can. Won't make it legal, but will make it quieter. http://www.ignitionproducts.com/Ignition/mufflers.html Link to comment Share on other sites More sharing options...
