Guest 06VFR Posted April 14, 2008 Share Posted April 14, 2008 I just installed a fuel pressure regulator from Turbo City, and was wondering if I need to eliminate the O2 sensor? I tried looking into other mod threads but could not find a straight answer to just that. All others included with a PC Commander. The only mod I have is a staintune exhaust. Any suggestions??? Link to comment Share on other sites More sharing options...
Member Contributer Vecky5 Posted April 14, 2008 Member Contributer Share Posted April 14, 2008 For what it's worth, I put on the 330 Ohm resistors from Radio shack and I don't have a Pciii. That seemed to eliminate the weak spot between 4-5K on my Vtec. For the $1 or so that they cost, it may be worth a try. Link to comment Share on other sites More sharing options...
Guest Posted April 15, 2008 Share Posted April 15, 2008 For what it's worth, I put on the 330 Ohm resistors from Radio shack and I don't have a Pciii. That seemed to eliminate the weak spot between 4-5K on my Vtec. For the $1 or so that they cost, it may be worth a try. Did you install the Fuel pressure regulator as well? I have the 300 ohm resistors, but I wanted to see if there was a diffrence with just the FPR. I;ll just have to ride :mellow: and see if it made a diffrence. Otherwise I'll be installing the resistors....Thanks Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted April 15, 2008 Member Contributer Share Posted April 15, 2008 Install the resistors. It will eliminate the lean surging at small throttle openings, particularly around 4-5krpm. The fuel injection will stay in map mode instead of leaning out the mixture. Link to comment Share on other sites More sharing options...
Guest Posted April 16, 2008 Share Posted April 16, 2008 I don't want to confuse you here and give differing information. But, when I installed my Turbo City FPR, I removed the 02 sensor eliminators that I had put on in the hopes of straightening out the lean/surge issue (02 eliminators did not work for me) Although I did do a starter valve synch when installing the FPR and My bike is completely sorted out now. I did synch all starter valves as close to equal with the non adjustable one as I could. My bikes been running great for about a couple of years now. I hope you have the same results. Link to comment Share on other sites More sharing options...
Question
Guest 06VFR
4 answers to this question
