LDSRIDER Posted March 20, 2006 Share Posted March 20, 2006 http://www.vfrdiscussion.com/uploads/1142781988/gallery_416_1291_31431.jpg[/img] A while back my motorcycle was hit by a large truck in a parking lot. (Some of you might remember the post) After waiting for the parts and time to do the work, I managed to get it all together to get ready for the riding season here in Colorado. Here is the "how to" on replacing the upper fairing ona VTEC VFR. mirrors.jpg remove the mirrors and set them aside. I do it in order to make things easier. screen cover.jpg remove the trim covers for the windscreen. screen.jpg Then the windscreen itself. left fairing.jpg remove the left and right fairings. bezel clip.jpg take out the 2 special clips by pushing in the center and then pull them out. bezel.jpg remove the bezel by pulling,with medium force on the 2 pins on either side. bezel trim.jpg remove the colored trim piece on either side of the bezel as well. upper fairing 3.jpg the only thing holding the fairing now is 2, 10mm nuts...remove them and drop the fairing down upper fairing 2.jpg take all light connections off and the temp. sensor. what to replace 1.jpg While it is removed, take out the light housings (phillips head screws) and the temperature sensor. grommet.jpg don't forget the grommets or clips 1.jpg the screw clips to go on the new fairing. check lights.jpg install everything back on the new part and connect your lights. Check them before going too far into the install. Go in reverse order as shown here and put it all together again. Here is the end result.... good as new.jpg Good luck!! Scott LDSRIDER Quote Link to comment Share on other sites More sharing options...
Forum CEO HispanicSlammer Posted May 29, 2007 Forum CEO Share Posted May 29, 2007 A while back my motorcycle was hit by a large truck in a parking lot. (Some of you might remember the post) After waiting for the parts and time to do the work, I managed to get it all together to get ready for the riding season here in Colorado. Here is the "how to" on replacing the upper fairing ona VTEC VFR. mirrors.jpg remove the mirrors and set them aside. I do it in order to make things easier. screen cover.jpg remove the trim covers for the windscreen. screen.jpg Then the windscreen itself. left fairing.jpg remove the left and right fairings. bezel clip.jpg take out the 2 special clips by pushing in the center and then pull them out. bezel.jpg remove the bezel by pulling,with medium force on the 2 pins on either side. bezel trim.jpg remove the colored trim piece on either side of the bezel as well. upper fairing 3.jpg the only thing holding the fairing now is 2, 10mm nuts...remove them and drop the fairing down upper fairing 2.jpg take all light connections off and the temp. sensor. what to replace 1.jpg While it is removed, take out the light housings (phillips head screws) and the temperature sensor. grommet.jpg don't forget the grommets or clips 1.jpg the screw clips to go on the new fairing. check lights.jpg install everything back on the new part and connect your lights. Check them before going too far into the install. Go in reverse order as shown here and put it all together again. Here is the end result.... good as new.jpg Good luck!! Scott LDSRIDER Quote Link to comment Share on other sites More sharing options...
