bsujanto Posted December 12, 2006 Share Posted December 12, 2006 I saw it somewhere in the web or perhaps in this forum, but can't find it anymore. A GPS mount which base is bolted to the surrounding of fuel lid, and a kind of plate extending foward a few inch to where the GPS unit sits approximately halfway between the fuel lid and steering stem. Do you know where I can find it? Thanks. Link to comment Share on other sites More sharing options...
theoxmole Posted December 12, 2006 Share Posted December 12, 2006 Is this the one? http://cgi.ebay.com/ebaymotors/Tank-Camera...sspagenameZWDVW If so, eBay's the answer. I think someone here actually had one for sale not too long ago. Try the classifieds as well. Link to comment Share on other sites More sharing options...
Member Contributer kwb377 Posted December 12, 2006 Member Contributer Share Posted December 12, 2006 I've got the eBay mount listed above for sale...looks like the ad got canked during the database meltdown. Looking for $25 shipped (CONUS) if interested. :fing02: Link to comment Share on other sites More sharing options...
bsujanto Posted December 12, 2006 Author Share Posted December 12, 2006 Is this the one?http://cgi.ebay.com/ebaymotors/Tank-Camera...sspagenameZWDVW If so, eBay's the answer. I think someone here actually had one for sale not too long ago. Try the classifieds as well. Yes, that's it. Thank you. I've got the eBay mount listed above for sale...looks like the ad got canked during the database meltdown. Looking for $25 shipped (CONUS) if interested. :fing02: Well, I'm not in US. I guess it will be difficult for an individual to serve me. I'm still wondering how I can attach the Garmin Quest to that mount. I think it needs a kind of bolted Garmin Quest base plate. Do you know how to do it? Link to comment Share on other sites More sharing options...
Member Contributer kwb377 Posted December 12, 2006 Member Contributer Share Posted December 12, 2006 Yes, that's it. Thank you.Well, I'm not in US. I guess it will be difficult for an individual to serve me. I'm still wondering how I can attach the Garmin Quest to that mount. I think it needs a kind of bolted Garmin Quest base plate. Do you know how to do it? No problem, I can ship it to you for the add'l shipping to your destination (whatever the Postal Service shows to your country). Not sure about the Quest mount...I just got a Ram cradle for my GPS V, and it bolts to their mount. Something like that could probably be adapted to the camera mount . Do you have a pic or link to the mount/base your referring to? Link to comment Share on other sites More sharing options...
Member Contributer Motor_Ref Posted December 12, 2006 Member Contributer Share Posted December 12, 2006 I saw it somewhere in the web or perhaps in this forum, but can't find it anymore. A GPS mount which base is bolted to the surrounding of fuel lid, and a kind of plate extending foward a few inch to where the GPS unit sits approximately halfway between the fuel lid and steering stem. Do you know where I can find it? Thanks. Just for the sake of curiosity, you migh take a peek at the RAM mount that bolts to the front tank bolts. It makes for a fairly clean looking installation. Link to comment Share on other sites More sharing options...
Lifttruck Posted December 12, 2006 Share Posted December 12, 2006 Yes, that's it. Thank you.Well, I'm not in US. I guess it will be difficult for an individual to serve me. I'm still wondering how I can attach the Garmin Quest to that mount. I think it needs a kind of bolted Garmin Quest base plate. Do you know how to do it? I don't want to step on anyone here but I would recommend a different base to mount your quest mont to also. I would suggest a base that bolts down using the two front tank bolts at the frame and then your selection of RAM arm and the RAM cradle for the Quest or Quest 2. Also get the powered harness to power your Quest so it remains backlit at night. It's a bit pricey but it's worth it! I currently use a Quest 2 and a RAM perch mount with a double ball. This set up allows me to adjust for clearance around my tank bag. I purchased my mounting hardware from Farklemasters. I recommend them highly! http://www.farklemasters.com/ Link to comment Share on other sites More sharing options...
Member Contributer kwb377 Posted December 12, 2006 Member Contributer Share Posted December 12, 2006 I would suggest a base that bolts down using the two front tank bolts at the frame and then your selection of RAM arm and the RAM cradle for the Quest or Quest 2. Also get the powered harness to power your Quest so it remains backlit at night. It's a bit pricey but it's worth it! I currently use a Quest 2 and a RAM perch mount with a double ball. This set up allows me to adjust for clearance around my tank bag.http://www.farklemasters.com/ I just did something similar, except I used RAM's 9mm-hole angled ball mount attached to the clip-on pinch bolt. I also got their camera mount for my 8mm or digicam. Link to comment Share on other sites More sharing options...
Lifttruck Posted December 12, 2006 Share Posted December 12, 2006 I just did something similar, except I used RAM's 9mm-hole angled ball mount attached to the clip-on pinch bolt. I also got their camera mount for my 8mm or digicam. I used the doubl ball on the perch mount so I could mount my XM radio off of the same mount. Link to comment Share on other sites More sharing options...
Member Contributer kwb377 Posted December 12, 2006 Member Contributer Share Posted December 12, 2006 Once I get into the 90's...I'll get an XM also (and ditch the 8mm for digital :fing02: ). Link to comment Share on other sites More sharing options...
bsujanto Posted December 13, 2006 Author Share Posted December 13, 2006 Guys, thanks for all the inputs. I'm still considering which way to go with installation of Garmin Quest. Using the 2 fuel tank front bolts is not in the choice due to scotts steering damper. The easiest is to follow RAM's suggestion with clutch/brake master clamp or U-bolt type. Cycle Machine camera mount combined with RAM's 9mm-hole angled ball mount is also a choice. I tend to like this more as I don't like the GPS to move around with the handlebar. I will let you know which way I choose. Link to comment Share on other sites More sharing options...
