Tool kit - C - Spasner
weewards
After many years having bikes with shaft drive I will probably be getting the VFR 800F-H I have been lusting over.
So I will need to periodically adjust the chain but my research shows that the standard toolkit does not include a C spanner, is that correct?
I am not sure if the bike I will be looking at even comes with a toolkit but if it does will I need to supplement it with a C Spanner just to do a basic task…
The standard tool kit does include the C-spanner + extension for the rear chain adjustment.  It also includes the wire helmet lock cable.
If your tool kit is missing the parts are still available from Honda.  My bike came without the tool kit so I had to buy all the pieces separately ( not available as a complete kit )
To save some dough, you can basically buy a used tool kit from any Honda off eBay, and most of the tools will be the same (you can check the parts fiche in advance if you want).  Then you only have to buy the ones that are missing from Honda.
(Better yet, buy some good quality tools instead of the "HONDA" marked cheapies...might actually work out cheaper!)
Ciao,
JZH
