Padraig Posted September 18 Share Posted September 18 Hi people just got my VFR 800 2002 back up and running with a good bit of work done on it but can’t get the ABS light off. New sensor put in. Any suggestions? Quote Link to comment Share on other sites More sharing options...
0 Member Contributer Grum Posted September 19 Member Contributer Share Posted September 19 7 hours ago, Padraig said: Hi people just got my VFR 800 2002 back up and running with a good bit of work done on it but can’t get the ABS light off. New sensor put in. Any suggestions? Not much detail in your fault description! - Are your tire pressures correct? - ABS is sensitive to battery status, is your battery and charging system good? - Are you saying that the ABS light remains On once bike speed is above 6mph? - Any physical damage to either of the Pulser Rings? - Are all four ABS fuses good? - Have you gone through the Service Manual for fault code checking? - Could the "work done" have effected ABS wiring and connections? - Was the issue there prior to work done? - What new sensor? Front or Rear? Did it have a fault code for the sensor? - Are the Sensor to Pulser Ring air gaps correct? - Have you checked all the ABS connections and connectors are clean and making good contact? Quote Link to comment Share on other sites More sharing options...
Question
Padraig
1 answer to this question
