I have a 95 vfr 750 and I am wanting to replace the analog gauges to digital one so need to know where to start this project
Bryanzx6r
What do you propose to use as the base for the digital display?
The good news is that the VFR750 is very simply wired.  The speedo uses a simple Hall-effect pulse generator, the tach pulse comes directly from the ECU, water temp is a simple sender, fuel gauge a simple potentiometer sender (US models also have a low fuel sensor inside the tank).  Indicator lights for turn signals, neutral, side stand and high beam.  Whatever you use for the digital part, the inputs shouldn't cause you much pain.  And the wiring diagrams for the US models should be on this forum somewhere--everything fits onto one page.
(Of course, I say all this off the top of my head!)
Good luck with your project.
Ciao,
JZH
