wawasonqo Posted April 15, 2023 Share Posted April 15, 2023 Hi Folks, In the attached image, you will see that I have highlighted Ref. No. 29 with a Red Ellipse. Does that go between the Master Cylinder and the Outside of the hole I have highlighted with a Red Circle? Thanks! Link to comment Share on other sites More sharing options...
Member Contributer Bren Posted April 15, 2023 Member Contributer Share Posted April 15, 2023 Yes, goes between the master cylinder and the heat shield. It's a hard rubber washer. 3 is a spacer that goes in from the back and 2 the nut. Link to comment Share on other sites More sharing options...
Member Contributer Bren Posted April 15, 2023 Member Contributer Share Posted April 15, 2023 Link to comment Share on other sites More sharing options...
wawasonqo Posted April 15, 2023 Author Share Posted April 15, 2023 4 hours ago, Bren said: Yes, goes between the master cylinder and the heat shield. It's a hard rubber washer. 3 is a spacer that goes in from the back and 2 the nut. The washer I have is metal. Ref. No. 3 is the Rubber Grommet that fits into the Heat Shield. Link to comment Share on other sites More sharing options...
Member Contributer Bren Posted April 15, 2023 Member Contributer Share Posted April 15, 2023 It may be that I swapped it out. Either way you know how it goes together so off you go! Link to comment Share on other sites More sharing options...
