Modgr Posted August 20, 2020 Share Posted August 20, 2020 Does anyone know how to remove the lid from the OEM panniers on the 8th gen? I had a bump the other day and I need to get the lid off to do a fibreglass repair and respray it but I cant figure out for the life of me how to get it off and I dont want to brute force it and damage it. Any help or advice would be much appreciated. Cheers. Link to comment Share on other sites More sharing options...
Member Contributer gmtech94 Posted August 20, 2020 Member Contributer Share Posted August 20, 2020 Push the pins on the bottom of the case out . You may need to drill a hole on the opposite end of them to get them out but not a problem down the road . Link to comment Share on other sites More sharing options...
Modgr Posted August 20, 2020 Author Share Posted August 20, 2020 8 minutes ago, gmtech94 said: Push the pins on the bottom of the case out . You may need to drill a hole on the opposite end of them to get them out but not a problem down the road . Thanks, that makes sense, but I wasnt sure if there was some kind of trick or special tool to pull the pin out from the open side. Link to comment Share on other sites More sharing options...
Modgr Posted August 20, 2020 Author Share Posted August 20, 2020 2 hours ago, gmtech94 said: Push the pins on the bottom of the case out . You may need to drill a hole on the opposite end of them to get them out but not a problem down the road . Got them out eventually but f**k me they took a hell of a hammering. Honda didnt mess around securing them! Link to comment Share on other sites More sharing options...
Member Contributer gmtech94 Posted August 21, 2020 Member Contributer Share Posted August 21, 2020 Glad it worked out ,I have done a few of them and some are easy and others must be glued in place . Link to comment Share on other sites More sharing options...
Modgr Posted August 21, 2020 Author Share Posted August 21, 2020 8 hours ago, gmtech94 said: Glad it worked out ,I have done a few of them and some are easy and others must be glued in place . These were definetly glued in place at the knurled end of the hinge pin!! Think I will be replacing it with something a bit easier to get off in future!! Link to comment Share on other sites More sharing options...
