Blake Posted May 12, 2018 Share Posted May 12, 2018 I recently rebuilt my vacuum fuel valve on my 1985 VF500F, it was gutted when I bought the bike. The new valve works when the bike is off no fuel flows, no leaks, no fuel coming out of the vacuum line when vacuum is applied. My problem is that the bike will run with the fuel valve on off. I rode 3 miles and there was no sign of it stopping. I have taken apart the valve and re checked to be sure I put the parts in correctly and they seem to be. Can anyone give me some help in why this valve doesn’t work? Can you run a bike for that long with the valve on off, I wouldn’t think so? Thanks Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 12, 2018 Member Contributer Share Posted May 12, 2018 There is a separate rubber that controls the on-off-reserve. It requires drilling the rivets and tapping M3 http://400v4service.nl/content/2014/12/Reparatie-benzinekraan-RC-30-dec-2014 Link to comment Share on other sites More sharing options...
Blake Posted May 12, 2018 Author Share Posted May 12, 2018 Thanks Dutchy but this is not the fuel valve I have. The inside does not have the 4 ports. This is a pic before I rebuilt it. It was gutted on the inside. Link to comment Share on other sites More sharing options...
Blake Posted May 12, 2018 Author Share Posted May 12, 2018 Fuel valve pic is before rebuild Link to comment Share on other sites More sharing options...
Blake Posted May 13, 2018 Author Share Posted May 13, 2018 Dutchy you was right! It is the rubber gasket in the on off reserve knob. Sorry for misunderstanding you at first. So do you happen to know where to buy these rubber gasket parts? thanks Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 13, 2018 Member Contributer Share Posted May 13, 2018 http://www.nrp-carbs.co.uk/shop/index.php?route=product/category&path=42 But beware, HONDA fitted different taps during the VF500F's reign.... I ordered the wrong one, but luckily the guy that was helping me had one from a VFR400 on hand. So we could fix right away. So if your bike is not your daily runner, I'd open the tap, measure the diameter and drop NRP a note when you order. Just to be 100% sure before the enveloppe crosses the Atlantic. Link to comment Share on other sites More sharing options...
Blake Posted May 13, 2018 Author Share Posted May 13, 2018 Ok and ill be sure to measure.I have an 800 as my daily runner so no problem if this sits. Thanks a packet. Really appreciate your help Blake Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 14, 2018 Member Contributer Share Posted May 14, 2018 You are very welcome; that is what VFRD is for.... Link to comment Share on other sites More sharing options...
Member Contributer InvisibleCities Posted May 22, 2018 Member Contributer Share Posted May 22, 2018 Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 22, 2018 Member Contributer Share Posted May 22, 2018 That is NOT the rubber that governs On-Off-Reserve. The one shown is the vaccuum valve that shuts when the engine stops when carb #1 stops sucking. Link to comment Share on other sites More sharing options...
Member Contributer InvisibleCities Posted May 22, 2018 Member Contributer Share Posted May 22, 2018 16 minutes ago, Dutchy said: That is NOT the rubber that governs On-Off-Reserve. The one shown is the vaccuum valve that shuts when the engine stops when carb #1 stops sucking. thanks, yes, you are right - i was simply showing the individual components for the petcock as the op said his was 'gutted' Link to comment Share on other sites More sharing options...
Blake Posted May 24, 2018 Author Share Posted May 24, 2018 Thanks guys. I did rebuild the vacuum side of the valve. I found out later that the petcock was not shutting off. Ordered the parts from NRP carbs in the UK but they sure are slow shipping them. This should resolve my petcock issues and return it to spec. Thanks again Link to comment Share on other sites More sharing options...
