Stevewils Posted February 5, 2018 Share Posted February 5, 2018 Hi All, So this weekend I changed my front sprocket from a 16T to a 15T. Pretty low cost item, only £16 including postage, and took about 2 hours in total to swap over. The only difficult bit was the piston falling out of the clutch slave cylinder, so I had to bleed the clutch fluid. My fault for not taping it up... There's a noticeable difference in 1st, 2nd & 3rd, seems to pick up a bit quicker, higher speeds can't seem to feel any difference. Gear indicator and quickshifter both still work. I would certainly recommend it for a low cost upgrade. Link to comment Share on other sites More sharing options...
Killerkingdon22 Posted February 5, 2018 Share Posted February 5, 2018 Would you post the link where you ordered? any pictures or a write up? Sorry to hound you - just thinking of doing this for my next mod thanks, Andy Link to comment Share on other sites More sharing options...
Stevewils Posted February 5, 2018 Author Share Posted February 5, 2018 I used this sprocket. https://www.chainsandsprockets.co.uk/products/jtf1332-rubber-cushioned-front-drive-motorcycle-sprocket-15-teeth-jtf-1332-15-rb Sorry I didn't take any pictures, it was the first time I attempted it so didn't want pictures of me cocking it up! I followed the procedure in the service manual and it was fairly straight forward. I will be checking it in a couple of weeks, I will take some pictures then and produce a procedure if there's demand for it. Link to comment Share on other sites More sharing options...
Killerkingdon22 Posted February 6, 2018 Share Posted February 6, 2018 Thanks Stevewils - ordered one this morning from JT. I didn't purchase the one with the rubberized foam pc, I have seen this in on my enduro bike's - but was under the assumption that it was for a quiet drivetrain, but not real performance needed. Will do a video when I install in the next two weeks. Link to comment Share on other sites More sharing options...
Stevewils Posted February 6, 2018 Author Share Posted February 6, 2018 44 minutes ago, Killerkingdon22 said: Thanks Stevewils - ordered one this morning from JT. I didn't purchase the one with the rubberized foam pc, I have seen this in on my enduro bike's - but was under the assumption that it was for a quiet drivetrain, but not real performance needed. Will do a video when I install in the next two weeks. The standard has a rubberised patch so just replaced like for like. Be careful with the piston on the slave clutch cylinder, mine fell out and I had to bleed the clutch system. Not difficult but just a pain when you don't need to. Steve. Link to comment Share on other sites More sharing options...
Killerkingdon22 Posted February 8, 2018 Share Posted February 8, 2018 Will do - thanks for the advice! Link to comment Share on other sites More sharing options...
Killerkingdon22 Posted May 2, 2018 Share Posted May 2, 2018 In the shop right now - hope to pick her up this weekend. Had my second service done early - think she is at 700 miles now with a total of three services!! LOL - New levers and sprocket, along with full lube and service. Will make for a great video on the road back home. Link to comment Share on other sites More sharing options...
