Silvo Posted May 28, 2017 Share Posted May 28, 2017 Hi all I have seen somewhere that someone had a problem with vibration which resulted in selling.. I have struggled with the same problem for a long time which I have finally resolved!!! I discovered that one of the oxygen sensors was fouled which caused cylinder 1&2 to run leaner than 3&4 !! Also check & clean the reed valves! ! This also causes throttle response issues.. silky smoothe now!!!!!!! Link to comment Share on other sites More sharing options...
Member Contributer GatorGreg Posted May 28, 2017 Member Contributer Share Posted May 28, 2017 12 minutes ago, Silvo said: Hi all I have seen somewhere that someone had a problem with vibration which resulted in selling.. I have struggled with the same problem for a long time which I have finally resolved!!! I discovered that one of the oxygen sensors was fouled which caused cylinder 1&2 to run leaner than 3&4 !! Also check & clean the reed valves! ! This also causes throttle response issues.. silky smoothe now!!!!!!! Silvo, do you have an 8th gen? This is the 8th gen subforum but your profile says you have a VFR1200? Glad to hear you resolved your problem though. Link to comment Share on other sites More sharing options...
