PACIFICMAN Posted August 24, 2015 Share Posted August 24, 2015 Hello all, I discovered brake fluid oozing from my rear master cylinder. the unit is damp from the "Reservoir hose joint" on down. The hose at this joint is held on with a "spring clip" not a hose clamp. This seems like a likely culprit. I topped up the reservoir (half full when I opened it) and I will get into the problem on Wednesday. I am however curious if anyone else has had experience with this issue and / or has any thoughts on resolving it. The brakes are unaffected and I caught the fluid loss before the system sucked air. Link to comment Share on other sites More sharing options...
