OnAnySunday Posted August 5, 2015 Share Posted August 5, 2015 Hello VFR Gang. I need some help, my 94' vfr750 fuel gauge is giving incorrect readings. What is required for this to work? What is there to replace? Is this a common problem? Cheers :) Link to comment Share on other sites More sharing options...
otmaximus Posted August 5, 2015 Share Posted August 5, 2015 If you drain the tank and remove the fuel level gauge from the bottom you can inspect it. Maybe it's bent. After an accident I had to swap tanks and replace the fuel level gauge. Since then it only reads about 3/4 when topped off. But I always reset the trip meter when I fuel up so I know how much gas I have. Link to comment Share on other sites More sharing options...
OnAnySunday Posted August 6, 2015 Author Share Posted August 6, 2015 It was working then stopped, no crash. It is just a rod with a floating device inside? Link to comment Share on other sites More sharing options...
