fabio222 Posted November 18, 2014 Share Posted November 18, 2014 Hi, What direction do you turn the knob on the headlights (the white colored one for vertical adjustment) for vertical adjustment? Ice tried both ways but I don't see a big difference at all really. I'd like to refit the HiD kits I had but don't want them pointing skyward! Link to comment Share on other sites More sharing options...
MrWabbit Posted November 25, 2014 Share Posted November 25, 2014 Hi Fabio, it does work. Position your bike about 3 meters or so from a garage door when its dark enough, set the bike on the centre stand and then turn on the lights, you will see the cut off pattern on the door. Put masking tape over this line. If you now turn the screw , you will notice it moving up and down over your tape. I installed a HID kit and found that actually i had the same cut-off so i just left it. I purchased a dip-able H4 HID replacement set. When you activate the high beams, the hid bulb actually changes position to give a different pattern. My lights are not comparable to what they were (much much better) and i have not noticed anyone beaming me so I don't beleive i'm blinding anyone. Link to comment Share on other sites More sharing options...
