Okay... my right headlight decided to stop working. Upon investigation it appears a previous owner decided to slice and dice the connections. Beyond repair at this point - the correct connector to the bulb is missing and there is almost no wire left to splice into in any case.
I want to put a new harness on.
I am wondering how tough it is to replace the harness - is it a simple plug and play operation? Is it easiest to simply remove the entire fairing set?
Finally, is there a separate harness for each side or a single harness for the entire headlight assembly?
This is what I am planning on purchasing:
As always, thanks!
Oh, and is there anything else I should go ahead and replace or upgrade while I have the entire assembly apart?
Sorry to hear that you are having to undo what the PO did. I don't have answers to the questions about the harness itself, but while you have the cowl off (and yes: I'd be removing both sides and the front, I'd urge you to consider replacing the light bulbs themselves with LED units. Here's what I did, and I really like them (although I wish I had replaced both the high and low rather than just the low beams):
Posted (edited)
I thought I replied... I saw the LED thread and am considering it, but I hate the idea of cutting up a new harness. IS there a way to mount the LED bulbs without cutting into the harness?
In any case, I like the install you did - it looks very clean. Very tempting...
[edit:]
Never mind... I see how the harness works. Much happier to give that a go.
http://www.amazon.com/Generic-2500LM-5000K-Bright-Headlight/dp/B00LUALTMW/ref=sr_1_14?ie=UTF8&qid=1410895040&sr=8-14&keywords=H4+LED+headlight
Are these the same light?
Edited by Headonastick
  • 4 weeks later...
You absolutely DO NOT have to cut up the harness!
The only thing you need to do is un-tape the high-beam leads, un-click the HOT tab to the H7 bulbs, and push it into the H4 bulb clip.... then tape it up.
THAT'S IT.
You will then have High/Low beam on the H4 LED and your H7's will be un-used.
The discussion in the LED conversion thread was if you wanted to ALSO run the H7's as a driving light, or fog light... for example, I ran mine as "accent" lighting that click OFF when the High-beams are on... something you do not need to do.
It's literally a 10 minute job to re-wire and install the LED bulbs, you will also have to aim them DOWN a bit as they tend to light up the tops of trees on first install. Haha.
