Guest jmac1957 Posted August 12, 2014 Share Posted August 12, 2014 Ok going to paint bags. Anyone have an idea of how to remove hinge pins? It would make the job so much easier. I'm a little concerned about reinstalling them although I assume they are just a press fit. anyone? Link to comment Share on other sites More sharing options...
Member Contributer Conedodger Posted August 12, 2014 Member Contributer Share Posted August 12, 2014 I very carefully ground down the blind side of the hinge with a Dremel Tool until I could see the pin. I then took a small nail and hammer and drove the pins out. After painting, I was able to push the pin back in with the hammer and nail. Link to comment Share on other sites More sharing options...
Guest Posted August 12, 2014 Share Posted August 12, 2014 Tks Mark Sounds like a plan. John Link to comment Share on other sites More sharing options...
Member Contributer gmtech94 Posted August 12, 2014 Member Contributer Share Posted August 12, 2014 I have just drilled a small hole at the end of the pin ,if needed you can put a small amount of glue on the end to hold the pin once installed again not usually needed . Link to comment Share on other sites More sharing options...
