Guest slytherriault Posted February 22, 2013 Share Posted February 22, 2013 Folks, I bought my 2010 VFR 1200F last summer (2012) and put 7000km (about 4000 miles) on it in addition to the 2000km (1200 miles) it had as a Honda demo. Sched maintenance says I should change final drive (shaft) oil, coolant, clutch, and brake fluids by now. Is it really necessary considering the bike only has 9000km (5200 miles)? Opinions? Recommendations? Thanks Link to comment Share on other sites More sharing options...
BrianF Posted February 22, 2013 Share Posted February 22, 2013 I don't know where you got that info, but I'm looking at the official manual right now and it says brake fluid and clutch fluid replace at 12,000 miles. It's basically oil & filter and inspect everything until then. I change the final drive oil every other oil change (5,000 mile intervals). Worry less, ride more. And, seeing that you're from Toronto, go Habs! Link to comment Share on other sites More sharing options...
Guest Posted February 23, 2013 Share Posted February 23, 2013 Thanks BrianF, I wish I was in California too right now... I'd ride more ;), and yep, I'm on the Habs' side :) I used a European manual I found on line and it talks about years for service rather than mileage, except for engine oil where it says every 5000 miles... crazy, I change my oil twice as often, but I'm happy you talked about the final drive oil... I guess I should at least change that before my riding season start... only 30 degrees around here until April when it goes back to riding temp ;) Cheers Link to comment Share on other sites More sharing options...
