Guest Bubbaslye Posted August 21, 2012 Share Posted August 21, 2012 Have had a number of bikes over the years and have found comfortable seating to be an issue with most of them. At present, I've two machines -- my VICTORY Cross Country has a stock seat that is the closest to a genuinely comfortable motorcycle that I've ever owned...ever! My 2010 VFR 1200f ( purchased this past May ) has, I'm sorry to say, the MOST UNCOMFORTABLE seat I've ever experienced...ever! There are a few after market seats out there, but they are expensive. Seeking a solution, I tried an Airhawk air cushion I had in the garage ( purchased when I had a BMW RT ) -- as was the case with the BMW, it failed to impress. Fast forward a couple of weeks -- my wife's neck pain prompted a purchase at the local drugstore -- one of those gel-filled pads that you place in a freezer to bring a little COOL comfort to the affected area. The size is roughly 9 x 11", the cost approximately $20. On a hunch, I went back to the drugstore & bought two of the pads; I skipped the freezer part ( no surprise there ) and simply slipped the two pads on top of the air cushion within the AIRHAWK cover. The difference, my friends, is tremendous -- the combination of those gel pads and a very modest amount of air in the cushion has worked wonders. In all, I've gone about 200 miles using the system with no seat discomfort whatsoever. Remember: you heard it here first! BUBBASLYE Link to comment Share on other sites More sharing options...
Graves Posted August 21, 2012 Share Posted August 21, 2012 Interesting. I love my Airhawk pad for the long hauls. Most people just don't know or forget the fact that they require very little air. I might give this a try to see if it changes anything for better or worse. Worse case is I have a cool pack or two for when I need them. Too bad they don't keep cool longer for those extra hot day rids. Link to comment Share on other sites More sharing options...
Member Contributer vanion2 Posted August 22, 2012 Member Contributer Share Posted August 22, 2012 I have used this successfully for some time now: http://www.vfrdiscussion.com/forum/index.php/topic/67135-costco-soft-gel-seat-cushion/ Keeps the pressure off the pressure points and the backside cool all day long. Link to comment Share on other sites More sharing options...
