Guest Hawk Posted July 27, 2012 Share Posted July 27, 2012 My Vfr seems to have some play in the grip before it actually feels like its opening the throttle its just like free play before you get to the springs that pull the throttle shut. Is there any way to take this out? Theres quite a bit of play on mine. Link to comment Share on other sites More sharing options...
V4 Rosso Posted July 27, 2012 Share Posted July 27, 2012 Yes, the cable adjusters are behind the left side middle fairing. Link to comment Share on other sites More sharing options...
Guest Posted July 28, 2012 Share Posted July 28, 2012 I adjusted it up on grip after watching a YouTube video seems to have worked. Link to comment Share on other sites More sharing options...
cbkenison Posted July 28, 2012 Share Posted July 28, 2012 I have found it best to set the adjuster on the handlebar in the middle, tighten up the carb one, and check slack when at full lock left and right. Slack usually tightens up full left for me. It is frustrating because there is a lot of slack when pointing straight forward Link to comment Share on other sites More sharing options...
V4 Rosso Posted July 28, 2012 Share Posted July 28, 2012 I adjusted it up on grip after watching a YouTube video seems to have worked. Yes, I had the adjuster mixed up with the slack adjuster for the petcock. Those are behind the left fairing (not on US spec bikes). Link to comment Share on other sites More sharing options...
