Member Contributer skirack Posted August 27, 2011 Member Contributer Share Posted August 27, 2011 Alright, I have about 1000 miles on my D&D slip on pipe. It makes my fourth gen. sound great, no complaints in that department. I am wondering from the others who might be running D&D pipes if you get a lot of exhaust popping when you let off the throttle (engine breaking) at RPM's above 4000. Is this normal for a slip on pipe or is it doing any damage to anything? BTW the bike is completely stock otherwise. No mods to air filter or carbs. Thanks Link to comment Share on other sites More sharing options...
Guest vfrrider Posted August 27, 2011 Share Posted August 27, 2011 Normal. D&D is very free flowing (i.e. LOUD) and will lean out the lean part of the fuel curve so you will get a little backfire at speed. Larry VFRrider Link to comment Share on other sites More sharing options...
Member Contributer Lobster Posted August 27, 2011 Member Contributer Share Posted August 27, 2011 I love my D&D...sounds great...but Dude wont ride behind me anymore... Link to comment Share on other sites More sharing options...
Member Contributer The mailman Posted August 27, 2011 Member Contributer Share Posted August 27, 2011 I've had mine on my '97 for about 5 years now. Same situation with some light popping on deceleration. It did it with the stock air filter/ jets and does it with the K&N filter and a recent complete carb tear-down. Spark plugs look nice and tan so there's no issue in that dept either. The D&D is about 1/3 the weight of the stock pipe and the sound level is a funny issue. The VFR crowd thinks they are too loud and my HD buddies keep asking me if the ike is even running. Link to comment Share on other sites More sharing options...
Member Contributer skirack Posted August 28, 2011 Author Member Contributer Share Posted August 28, 2011 Thanks for the input gentlemen! It's good to know that I don't need to add a jet kit or make any carb adjustments. Link to comment Share on other sites More sharing options...
Guest Posted August 30, 2011 Share Posted August 30, 2011 Pull the choke a little bit on deceleration, see if it pops anymore. Link to comment Share on other sites More sharing options...
spider Posted August 30, 2011 Share Posted August 30, 2011 I also have a D&D slip on and yes it does pop a little when i let off of it but i extended the mid pipe and mounted it under the tail so its not to loud. I think it has gotten better with a little age on it but it can get a little loud when you crank on it. Riding buddys laugh and tell me it sounds like they are watching nascar. Link to comment Share on other sites More sharing options...
Member Contributer Chuckster Posted August 31, 2011 Member Contributer Share Posted August 31, 2011 I've got a D&D slip-on, K&N air filter and stock jetting. Very light popping on decel. I think you're fine as it is. Link to comment Share on other sites More sharing options...
