Guest vfr750gaz Posted May 16, 2011 Share Posted May 16, 2011 Well i finished building my bike only to discover theres a discrepancy with the engine numbers on it. I have been offered a VFR750FL engine (low miles) quite cheap, but i need to know will it fit in a VFR750FR chassis and also will the carbs from the later FR engine fit it? Thanks in advance Gaz Quote Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 16, 2011 Member Contributer Share Posted May 16, 2011 Well i finished building my bike only to discover theres a discrepancy with the engine numbers on it. I have been offered a VFR750FL engine (low miles) quite cheap, but i need to know will it fit in a VFR750FR chassis and also will the carbs from the later FR engine fit it? Thanks in advance Gaz yes... the motor will fit.. not ure if you can swap the carbs Quote Link to comment Share on other sites More sharing options...
Guest nari Posted June 6, 2011 Share Posted June 6, 2011 Well i finished building my bike only to discover theres a discrepancy with the engine numbers on it. I have been offered a VFR750FL engine (low miles) quite cheap, but i need to know will it fit in a VFR750FR chassis and also will the carbs from the later FR engine fit it? Thanks in advance Gaz yes... the motor will fit.. not ure if you can swap the carbs so the engine will fit okay thats what i needed to know also, the carbs are what im needing to know also if the my 95 carbs will fit a 91 engine Quote Link to comment Share on other sites More sharing options...
Guest vfroem Posted June 12, 2011 Share Posted June 12, 2011 Well i finished building my bike only to discover theres a discrepancy with the engine numbers on it. I have been offered a VFR750FL engine (low miles) quite cheap, but i need to know will it fit in a VFR750FR chassis and also will the carbs from the later FR engine fit it? Thanks in advance Gaz yes... the motor will fit.. not ure if you can swap the carbs so the engine will fit okay thats what i needed to know also, the carbs are what im needing to know also if the my 95 carbs will fit a 91 engine You can use the old carbs: 94-97 engine has -smaller!- carbs. Will fit ! Quote Link to comment Share on other sites More sharing options...
