Guest mrg001 Posted June 14, 2009 Share Posted June 14, 2009 hi all- I have 92vfr, with TBR exhaust/mid pipe/headers and the can is a right exit high mount. I don't know anything about the system, it came with the bike when I got it a few years back. I recently changed the rear tire, and in changing it had to remove the can and move the mid pipe around (maybe should have removed it). Anyway, I now have an exhaust leak where the midpipe meets the headers. The clamp that is on there isn't doing the trick, and I don't want to put a sealant on there as I'm going to have to remove the midpipe whenever the rear tire is changed. Has anyone had a problem like this? Any ideas on how to handle something like this? As I mentioned, I don't want to put a permanent seal or weld on it, as I need it to be flexible for future tire changes. Any help would be greatly appreciated. Thanks. Link to comment Share on other sites More sharing options...
VIFFER93 Posted December 3, 2009 Share Posted December 3, 2009 I have a simimar TBR system for my '93. If you have torqued the fittings you might need to bring it to an exhaust shop and have them fit a new clamp to it. I am looking for a TBR system like you have would you want to sell it? Link to comment Share on other sites More sharing options...
Guest Posted December 3, 2009 Share Posted December 3, 2009 I dont have that exhaust but I would assume there is a gasket at the connection of the midpipe and headers. Might need to replace it, its made of some sort of lead like material, fairly soft. I'm a little surprised you had to touch it to get the rear wheel off...seems odd. Link to comment Share on other sites More sharing options...
