Guest Johnnyboy669 Posted May 31, 2009 Share Posted May 31, 2009 My '86 VFR750 is not charging...Does somebody know how to diagnose/isolate the problem? Any tips on finding reasonably priced replacement parts that I will need? Thanks very much! Link to comment Share on other sites More sharing options...
Member Contributer VFDoug Posted June 1, 2009 Member Contributer Share Posted June 1, 2009 What did you do to determine it's not charging? Did you put a volt meter on the battery while it was running and note the readings? What kind of shape is the battery in, and has it been load tested, is it full of water, etc? BTW, welcome to the forums. Link to comment Share on other sites More sharing options...
Guest Posted June 3, 2009 Share Posted June 3, 2009 What did you do to determine it's not charging? Did you put a volt meter on the battery while it was running and note the readings?What kind of shape is the battery in, and has it been load tested, is it full of water, etc? BTW, welcome to the forums. I've tried several batteries (even a new one) and they all eventually die...I can't remember the acutual voltage since it was last season, but I don't believe it was adequate (around 13.4 volts) Thanks for your help John Link to comment Share on other sites More sharing options...
