Guest EJS4029 Posted February 11, 2008 Share Posted February 11, 2008 Recently I picked up a Comagination Brake Light Flasher I misplaced the instructions I checked the website the install instructions are kind of vague. Has anyone installed one or something similar ? on their VFR if so can they provide me with some details or tips ? The unit is about the size of a Quarter and about 3/4 of an inch thick with a Black, Red And Green wire attached. Intelligent Brake Flasher Install It’s EZ to install just 3 wires. Interrupt your vehicle’s power brake wire feed to lights (cut or disconnect it) and attached the VisiStop black wire to the end going to the brake lights and the red wire to the other end. Then connect the green wire to the vehicle’s battery negative. Your done! Link to comment Share on other sites More sharing options...
Member Contributer Rivcyko Posted February 11, 2008 Member Contributer Share Posted February 11, 2008 http://www.webbikeworld.com/Reviewed-motor...op/visistop.htm Link to comment Share on other sites More sharing options...
Guest Posted February 11, 2008 Share Posted February 11, 2008 http://www.webbikeworld.com/Reviewed-motor...op/visistop.htm Thanks Rivcyko....Since my electrical skills are nil and without sounding stupid....My 06 Interceptor has two taillights so do I tap in to them before the harness ? Link to comment Share on other sites More sharing options...
