Guest VFR-RAY Posted September 17, 2007 Share Posted September 17, 2007 Hi all, looking for some help on what fork internals will work for my 20,000 mile 2002 VFR. ( something with clickers ) I believe some have used f4/ f4i internals here and would like to know if the change over has been with out problems . thanks great forum, Link to comment Share on other sites More sharing options...
Baileyrock Posted September 17, 2007 Share Posted September 17, 2007 Hi all, looking for some help on what fork internals will work for my 20,000 mile 2002 VFR. ( something with clickers ) I believe some have used f4/ f4i internals here and would like to know if the change over has been with out problems . thanks great forum, Yes, F4/F4i rebound valve & rod assy. work in the Vtec forks and provide Rebound adjustment along with the standard preload adj. The CBR rod assy is shorter, but it is still being used. I would only worry about it topping out against the valve body instead of the top out spring like it should(as per smarter people then me) :rolleyes: The stock compression valve assy(vfr) should still be used, but a revalve of it would also help. ps welcome to VFRD! :thumbsup: Link to comment Share on other sites More sharing options...
Guest Posted September 18, 2007 Share Posted September 18, 2007 Thanks for the reply, any input on stacking for a 165lb light wt ? :blink: Link to comment Share on other sites More sharing options...
