Guest talus Posted June 15, 2007 Share Posted June 15, 2007 So I'm working on my stator change and the one of the first things to do is disconnect the 4 electrical connectors that sit over the alternator cover. Two are simple to release. It's the other two 4 wire ones that I'm having trouble with. Soooooo.... how do you get these things apart? I'm talking about the gasket-ed type 4 pin ones. They look like they have multiple release clips to separate them. I don't get it. Then again I was a fairly slow learner with the plastic fairing pins. HELP Please! Sealed connectors Link to comment Share on other sites More sharing options...
Guest Posted June 16, 2007 Share Posted June 16, 2007 These are the 4 pin connectors I'm having issues with... DSCN0974.jpg Link to comment Share on other sites More sharing options...
Member Contributer radar Posted June 16, 2007 Member Contributer Share Posted June 16, 2007 I am no expert, but I have certainly pulled apart my share of connectors in the last couple days, you should be able to push the side tab outwards and then pull apart, but I understand that they can be stubborn Link to comment Share on other sites More sharing options...
Guest Posted June 16, 2007 Share Posted June 16, 2007 Thanks Radar - I'll give it a try. It's like they have three or four hooks holding them together. Link to comment Share on other sites More sharing options...
Guest Posted June 16, 2007 Share Posted June 16, 2007 It's just held in by one tab. In your picture of the black connector, it's directly below the "rounded" part. Just move it aside with a small screwdriver and it comes apart. Link to comment Share on other sites More sharing options...
Guest Posted June 16, 2007 Share Posted June 16, 2007 Ok - I got them...THANKS! They are a right b*&%$ to get open - there was a fair bit of suction since they have a gasket. Despite the crud on the outside and where I was handling them for the pics they were spotless inside. I do understand now that there is only ONE tab to move... the inner one (lift the tab with the red arrow). Hope this helps someone else. Sealed Connectors 1.jpg Sealed Connectors 2.jpg Link to comment Share on other sites More sharing options...
