Member Contributer Laird Posted August 23, 2006 Member Contributer Share Posted August 23, 2006 I recently got a Garmin StreetPilot 2720... Love it, though I'm still learning all of its features. I've programmed a number of routes into the unit, but I haven't figured out how to tell it to follow my programmed route. Since I'm attending the Dragon ride in mid-September, figuring this feature out has become a high priority! -Laird Link to comment Share on other sites More sharing options...
Guest Posted August 23, 2006 Share Posted August 23, 2006 I've got a 2730 so I assume it is the same. Hit the find button, then touch either "recent finds" or "favorites" (if you stored the destination as a favorite). Then touch "goto" in the bottom right corner and it should calculate the route. Hope this helps. Dave Link to comment Share on other sites More sharing options...
mellowyellow Posted August 23, 2006 Share Posted August 23, 2006 I recently got a Garmin StreetPilot 2720... Love it, though I'm still learning all of its features. I've programmed a number of routes into the unit, but I haven't figured out how to tell it to follow my programmed route.Since I'm attending the Dragon ride in mid-September, figuring this feature out has become a high priority! -Laird any install pics I just bought the same unit and am waiting for motorcycle kit I ordered Link to comment Share on other sites More sharing options...
Member Contributer Laird Posted August 23, 2006 Author Member Contributer Share Posted August 23, 2006 I've got a 2730 so I assume it is the same. Hit the find button, then touch either "recent finds" or "favorites" (if you stored the destination as a favorite). Then touch "goto" in the bottom right corner and it should calculate the route. Hope this helps.Dave What's strange is that when I've tried that so far, it calculates a new route and doesn't follow my existing preference (which is normally very different than the 'shortest distance' autocalculation). I had looked for a spot in the menu to select a particular route and couldn't find anything. I guess I'll have to experiment with it a bit more to get it to follow my programmed route. -Laird Link to comment Share on other sites More sharing options...
Member Contributer Laird Posted August 23, 2006 Author Member Contributer Share Posted August 23, 2006 any install pics I just bought the same unit and am waiting for motorcycle kit I ordered Sorry, I haven't taken any pics since I installed it. I went with the tank-mount and standard arm. I had no problem using the stock tank bolts, though I did remove the rubber spacers from the top. The Powerlet outlet kit for the left inner fairing (http://powerlet.net/products/honda_leftpanel.php) is great. I shortened the powerlet-to-garmin power cable (PPC-003 on powerlet's site) and that was it! -Laird Link to comment Share on other sites More sharing options...
Guest Posted August 23, 2006 Share Posted August 23, 2006 What's strange is that when I've tried that so far, it calculates a new route and doesn't follow my existing preference (which is normally very different than the 'shortest distance' autocalculation). I had looked for a spot in the menu to select a particular route and couldn't find anything. I guess I'll have to experiment with it a bit more to get it to follow my programmed route.-Laird If it's like my 2610 you don't use the find button. I actually have a "routes" touch screen option on my menu. Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted August 23, 2006 Member Contributer Share Posted August 23, 2006 It is probably different from mine, I have a Quest, but here's what I do to access preprogrammed routes: Press Menu, select Route Options, select Route Planner, then select the route I want. Link to comment Share on other sites More sharing options...
Guest Posted August 23, 2006 Share Posted August 23, 2006 It is probably different from mine, I have a Quest, but here's what I do to access preprogrammed routes: Press Menu, select Route Options, select Route Planner, then select the route I want. Sounds similar to my 2610. Link to comment Share on other sites More sharing options...
Member Contributer Laird Posted August 24, 2006 Author Member Contributer Share Posted August 24, 2006 If it's like my 2610 you don't use the find button. I actually have a "routes" touch screen option on my menu. Thanks Ratfink... I found it... It was buried a lot deeper than I expected! (Menu) -> Tools -> My Data -> Routes -> Navigate Saved Route -> (pick a route) -Laird Link to comment Share on other sites More sharing options...
