mordantly Posted June 13, 2016 Share Posted June 13, 2016 I am retrofitting a 83 vf750f that was stripped to be a track bike back to DOT compliant. Got a center stand spring and plate and pivot pin off magna or some similar bike. Where does the spring plate pivot? Found a nub near the pinch bolt of pivot pin but spring too long for that location. Link to comment Share on other sites More sharing options...
Member Contributer CBVFRbikeboy Posted June 13, 2016 Member Contributer Share Posted June 13, 2016 That's where mine goes. Maybe the spring is wrong? Link to comment Share on other sites More sharing options...
Member Contributer bswiles Posted June 13, 2016 Member Contributer Share Posted June 13, 2016 12 hours ago, mordantly said: I am retrofitting a 83 vf750f that was stripped to be a track bike back to DOT compliant. Got a center stand spring and plate and pivot pin off magna or some similar bike. Where does the spring plate pivot? Found a nub near the pinch bolt of pivot pin but spring too long for that location. If you give me the measurements of your spring, I will compare it to mine. I actually left my center stand off after mine was restored. Link to comment Share on other sites More sharing options...
mordantly Posted June 14, 2016 Author Share Posted June 14, 2016 Thanks guys! That is the lug I had found. The magna must be different.. This spring is 4 7/8 inside the hooks.. Link to comment Share on other sites More sharing options...
