Member Contributer crazybrother Posted September 12, 2012 Member Contributer Share Posted September 12, 2012 Hey guy's does anyone know if the levers are the same on the Sixth and Seventh Gens? I know that the Throttlemeister throttle lock is the same, but I can't seem to find any info on the levers. I'm looking for some Pazzo's but can't find them. Thanks. Link to comment Share on other sites More sharing options...
vfrflanders Posted September 12, 2012 Share Posted September 12, 2012 More info in this topic (#5): http://www.vfrdiscussion.com/forum/index.php/topic/71284-what-parts-has-the-vfr-1200-in-common-with-other-hondas/page__hl__levers Link to comment Share on other sites More sharing options...
Guest Posted September 13, 2012 Share Posted September 13, 2012 Why, do you need stock levers for the 1200? I have a set that will never see my motorcycle again because Pazzo shorties look and feel a ton better and you can have them cheap. Link to comment Share on other sites More sharing options...
Member Contributer crazybrother Posted September 24, 2012 Author Member Contributer Share Posted September 24, 2012 Why, do you need stock levers for the 1200? I have a set that will never see my motorcycle again because Pazzo shorties look and feel a ton better and you can have them cheap. With your Pazzo's installed does your brake switch still work on the front lever? Link to comment Share on other sites More sharing options...
Guest Posted September 24, 2012 Share Posted September 24, 2012 Why, do you need stock levers for the 1200? I have a set that will never see my motorcycle again because Pazzo shorties look and feel a ton better and you can have them cheap. With your Pazzo's installed does your brake switch still work on the front lever? Yes, the brake light switch works fine. Link to comment Share on other sites More sharing options...
