Guest redrider740 Posted August 25, 2011 Share Posted August 25, 2011 The other day I noticed my right headlight (low beam) was out and I am going to replace it. What I was wondering is what any of you have done? Should I go with stock bulbs again from the dealer which I'm sure are going to be somewhat expensive for a light bulb, or should I try some other lights and if so which ones have you guys used with good results. Thanks for any advice/help. Link to comment Share on other sites More sharing options...
Member Contributer 5thGenJim Posted August 25, 2011 Member Contributer Share Posted August 25, 2011 The other day I noticed my right headlight (low beam) was out and I am going to replace it. What I was wondering is what any of you have done? Should I go with stock bulbs again from the dealer which I'm sure are going to be somewhat expensive for a light bulb, or should I try some other lights and if so which ones have you guys used with good results. Thanks for any advice/help. lots of options, my friend...Some are discussed here. Link to comment Share on other sites More sharing options...
Guest Posted August 26, 2011 Share Posted August 26, 2011 The other day I noticed my right headlight (low beam) was out and I am going to replace it. What I was wondering is what any of you have done? Should I go with stock bulbs again from the dealer which I'm sure are going to be somewhat expensive for a light bulb, or should I try some other lights and if so which ones have you guys used with good results. Thanks for any advice/help. lots of options, my friend...Some are discussed here. Yeah I briefly read through some old stuff on here and was probably going to just do the tab bending thing, but does anyone know if the newer style white/blueish lights that are out now will work in a 4th gen at all because I wouldn't mind some of those on my bike. Link to comment Share on other sites More sharing options...
