Guest jmunguia29 Posted May 9, 2011 Share Posted May 9, 2011 Hello, so I recently bought this bike about 2 months ago and have been trying to get the tach to work. The speedometer works fine. When the bike is running the tach needle elevates a little but never works. Any wires to check or anything on the gauge I could look at? Link to comment Share on other sites More sharing options...
Guest Posted May 10, 2011 Share Posted May 10, 2011 my tach isnt working on my 87 vfr 700 but, like yours, all the other gauges work. im trying to figure out how to get mine working too. Link to comment Share on other sites More sharing options...
Guest Posted May 30, 2011 Share Posted May 30, 2011 Check the electrical system - If you refer to my post you'll see how I'm troubleshooting - in part - 1. Coils packs 2. ECU ( or spark boxes ) 3. Pulse generators - trying next good luck Marty Link to comment Share on other sites More sharing options...
Guest Posted May 30, 2011 Share Posted May 30, 2011 The tach operates off the coil and spark unit for cylinders 1 & 3, yellow wire, check the connectors. Link to comment Share on other sites More sharing options...
Member Contributer FinVFR Posted May 30, 2011 Member Contributer Share Posted May 30, 2011 +1 to Creacy When I undressed my VFR I also forgot to connect the yellow wire when assembling the fairings back since all the other connectors were behind the instrumental panel except the yellow one for the tach. You very easily forget that... Link to comment Share on other sites More sharing options...
Guest Posted September 16, 2012 Share Posted September 16, 2012 on the first gen VFs the tach reads off the "spark unit" (as the parts guide calls it) for 1 and 3 behind the toolbox under the seat, if your tach doesnt work, you will have to replace the spark unit. finding one affordable is the hard part, installing it takes about 20 minutes and a cold beer on a nice day. as far as i know. dont remember which one is for 1-3 and which is 2-4 but the part numbers are (hitachi):30400-mb0-005 or (ND):30400-mb1-701 for the right side and (hitachi):30410-mb2-005 or (ND):30410-mb2-004 for the left. these numbers could be discontinued and/or changed since my part guide was printed in '84 (stealership would be able to tell you). Link to comment Share on other sites More sharing options...
