Guest edg Posted April 23, 2011 Share Posted April 23, 2011 So I replaced the front and rear brakes on my VFR and installed a Moty battery. Just powered the bike back up and the brake light is now staying on. I figure I'll try to figure out how to unhook each of the switches (handle and pedal) one at a time to see if one of the switches is at fault for some reason... .. any suggestions are appreciated. Thanks. Link to comment Share on other sites More sharing options...
Member Contributer Mac Posted April 23, 2011 Member Contributer Share Posted April 23, 2011 You can adjust the switch for the rear brake. Check your owners manual. It's probably the culprit. Mac Link to comment Share on other sites More sharing options...
Guest Posted April 23, 2011 Share Posted April 23, 2011 Good call, that was exactly it! Thanks! You can adjust the switch for the rear brake. Check your owners manual. It's probably the culprit. Mac Link to comment Share on other sites More sharing options...
